servo question
IN
servo question
ALL: I am building my first large scale ARF- 38% Extra 330- and tower hobbies site suggest that i use futaba high torque servos, is there a servo just as good but a little cheaper than futaba. I know I need high quality servos for this plane I was just looking for help on servo selection. Thank you in advance for the help. Bruce
RE: servo question
I would check different name brands against the specs, but I would be hesitant to go with a no-name servo on a plane that size.
Check the torque requirements specified for your plane against comparable Hitec servos, and then see if you can find them with a quantity discount at Tom's RC. They have the best prices I have found on higher torque servos, and quantity discounts on most items.
http://shop.tomsrc.com/index.php?cPath=76
I am not affiliated with these guys at all, I am just a satisfied customer.
Good luck
Good luck
RE: servo question
Ditto on the Hitec's, JR's or Futabas. Dont sacrafice a plane that large to junk servos, there's more than your wallet at stake if that thing crashes.
Chief Aircraft is my first stop as well. Call there and ask for Donnie, he flys all sorts of giant scale and will recommend the appropriate servos.
