engine/fuel question
I am running a OS 46 engine. It has a dozen flights on it and it has been running fine, I started out on 10% fuel and bought a field box that came with a gallon of 15% so I figured I'd use that. Anyway, engine starts fine, runs strong, I have the high end tuned pretty good. What's happening is after flying at half throttle for 15mins or so, I do some touch and goes and the go-around power is right there, no bogging. But when I land, within 30secs, sometimes quicker, as I add power to clear the runway it just dies. It didn't seem to do that on the 10% and that is the only thing that is different. Also, there seems to be excessive exhaust fuel down the side of the plane. Any thoughts on this?
Shane
Shane
RE: engine/fuel question
That being said, I turned the LSN clockwise about 1/16 of a turn, that may have been enough to cause a slight issue. I haven't tuned these engines in years so I was experimenting a bit, but just a bit.
SC
That would do it. You leaned it out. It doesn't take much on that low end needle to make a big difference. Put it back where it was and go from there.
SC
Do the pinch test for the high end. At full throttle, briefly pinch the supply line. If the engine dies immediately, it's too lean. If it runs a while, then slowly revs up, it's too rich. If it speeds up quickly and begins to die, it's about right.
And just because I'm learning I'll ask. The 10/15% rating is the amount of nitro in the fuel? Meaning 15% should have more kick or am I way off base here? Also for a relatively new engine should I be doing anything specific to it on a regular basis? Should I stay with the 10% vs 15%? Just curious.
My Feedback: (8)
15% requires a more open valve setting; more nitromethane needs less oxygen to burn, therefore would be running lean with no adjustment from 10% settings.
The increase in nitro content is mostly about the ability to burn more alcohol in the combustion chamber, since you can reduce the amount of air and increase the volume of fluid (it has a lower fuel:air ratio).
The only thing I noticed when going from 10%-15% on a .46 engine was a decrease in flight time. I don't believe it is worth the extra cost and reduced flight times for the small increase in power you get.
The increase in power gets more noticeable when you get into larger engines.
