Hitec Supreme RX- wrong one?
MI
Was just at Toledo show and bought a Hitec 8 ch supreme rx from MPI. I told the kid when he asked what radio, Hitec but he gave me one that says JR or Airtronics TX only. I'm using hitec prisim and Futaba sue 8 radios. what is the difference? Maybe I can email MPI and see if they will switch rx's but whata pain to send it and wait for another. any suggestions? TIA
Ron
Ron
NM
" but he gave me one that says JR or Airtronics TX only. I'm using hitec prisim and Futaba sue 8 radios. what is the difference? "
Flats: I don't think that you have a choice. JR & Airtronics use a posative shift pulse, and Hi-Tec & Futaba use negative shift. I'd get right on the horn to them and have them straighten it out.
Tell them to send it Overnite Express, it was their mistake.
Ron it was a bit hard to tell what transmitter you are using from your post but if you using a Hitec Prism 7X transmitter it will work fine with that Rx. It will be neccessary for you to use the shift select feature of your radio to enable positive shift. The Prism 7x functions with both high or low shift. Not sure which model Futaba you have but it is probably not selectable and in that case as Jim said it will not work with that Rx.
John
John
MI
thanks guys for the responces...I have a hitec Prism 7 and I am now using a Futaba super 8U...if the hitec has the shift select than the Super 8 probably does also....I'll get one of the guys in the club to check it out. thanks again
Ron
Ron
