 Can I swing this? >
Can I swing this?
Can I swing this?
Old 07-11-2010 | 07:42 PM
Banned
Default Can I swing this?
I have a Hangar9 Fokker DVII ARF with an OS .61FX engine. I had been swinging a 13 x 6 wooden prop (Zinger) and with my second flight, I ran the 14 x 6 wooden (Also a Zinger) -
I was wondering, since I like how it handled the second time around and how it looked on the plane, if I would be able to continue to swing that prop without screwing up my engine?
I know at times we can't go by company guidelines, because OS .91FX loved a 14 x 7 triple prop (Master Airscrew plastic) on my late Extra and it loved it.
Pete
Old 07-11-2010 | 08:35 PM
proptop's Avatar
My Feedback: (8)
Default RE: Can I swing this?
My .61FX ran quite well with an APC 13x6...the Zingers put more load on an engine...a 14x6 Zinger...hmmm...
A 14x6 is quite a load for a .61, and will probably shorten the life of the connecting rod, among other things...but if you don't run it too lean...it should be ok for a while.
With the hot weather we've been having, I don't think I would do it...but it's your engine...(like I said, it might be ok for a while, but...? )
Old 07-11-2010 | 09:05 PM
Banned
Thanks, I'll do that then. I appreciate the help.
Pete
Old 07-11-2010 | 10:08 PM
Might want to consider going to a lower pitch. Go with a 14 x 5 which would be less stress on the engine.
Old 07-12-2010 | 01:44 AM
A 14x6 prop on a .61 is asking a lot, it is more of prop for a .75 . You could easily over heat the motor. Best to stay with the 13x6. The only .61 motor I ever owned that could possible turn a 14x6 was a Fox Eagle III, the motor was built for torque not for speed.
