Converting the Hobbistar to Bolt on Wing >
Old 07-24-2003 | 01:12 PM
CCDave's Avatar
My Feedback: (53)
Default Converting the Hobbistar to Bolt on Wing
Has anyone converted the Hobbico Hobbistar to a bolt on wing? I have been trying to figure out how to do this and I'm not sure of the best way to do it... I am concerned that my design wouldn't be strong enough....
I would like to see pictures if possible...
If no one has pictures of a hobbistar conversion any similar plane should help me figure this out...
Old 07-24-2003 | 03:41 PM
tailskid's Avatar
My Feedback: (34)
DuBro sells some neat blocks/bolts for just that purpose. The plastic blocks just bolt thru the fuse sides and you drill out the wing for the bolts.
Jerry
Old 07-24-2003 | 06:10 PM
CCDave's Avatar
My Feedback: (53)
Tailskid,
I have that kit but the main thing I am wondering is how to secure the front of the wing... I need to put a dowel in it but I just have questions about how best to do this...
BTW it is a MKIII
Old 07-24-2003 | 09:16 PM
FLYBOY's Avatar
Forget the dowel, use 4 bolts. Make sure you put some ply on the wing so the bolts don't pull through, use a 1/4 inch play plate in the fuse that sits right against the bottom of the wing, and put a 1/2 inch triangle stock on the bottom of that plate to the fuse side epoxied on for strength. You can use a 1/8th inch ply plate on the back of the wing where you drill through, but on the front you will probably have to go in and put a 1/8 or 1/4 inch plate in for the head of the screw with triangle stock on the ribs to hold it on. Make sure it is good so you don't rip the wing off. Also use the correct numbered bit before you tap the 1/4 inch ply plate so it is the right size and the screw fits right. Use thin CA in the threads and tap a second time after it drys to clean out the threads.
