RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Changing Kavan Starter brushes (https://www.rcuniverse.com/forum/questions-answers-154/10135442-changing-kavan-starter-brushes.html)
DennisD 11-14-2010 08:43 PM
Hi Everybody:
Well, after 35 years, my brushes finally wore out on my Kavan Starter.
I ordered a new set and they don't look quite the same as what I have.
Anybody know how to change the brushes in a Kavan starter?
If so, I would appreciate step by step instructions, please!!
Regards,
Dennis
Lnewqban 11-14-2010 09:22 PM
RE: Changing Kavan Starter brushes
Different brand, but similar principle may be?
http://www.rcuniverse.com/forum/m_10...m.htm#10043136
w8ye 11-15-2010 01:54 AM
You may have to file or sand the brushes so they will fit in the holders
I have worked on Sullivan and Hobbico/Tower starters.
I assemble the bushes on the back plate.
Install the armature only onto the backplate and bearing. You can hold the brushes back with you fingers.
Hold the armature down and slide the field down over the armature.
Then install the front bearing plate
No need for strings or wires to hold the brushes back.
DennisD 12-21-2010 04:59 PM
For anyone who is interested, I e-mailed Kavan and they sent me a pdf file with instructions.
If anyone needs it, let me know and I'll post it here if I can.
Regards,
Dennis
w8ye 12-21-2010 06:29 PM
Try to post it anyway
w8ye 12-21-2010 06:31 PM
The reduction gear and front shaft bearing will eventually fail in the Kavan starter. They are a nice starter and people keep them for years
DennisD 12-22-2010 12:08 PM
1 Attachment(s)
OK, Here's the pdf file.
DennisD 12-22-2010 12:12 PM
ORIGINAL: w8ye
As I said in my first post, I've had mine for 35 years, and it's now right back to where it was after I changed the brushes. Best investment I've ever made in this hobby.
Regards,
Dennis
