CANOPIES
Is there anyone out there that makes clear plastic canopies, in different sizes? I'm building two Stuka's .60 scale 60" wingspans, ans I need canopy's made for them, maybe there is even tips on how to make canopies I don't know Unfortunatly both my planes are pre-war proto types, so the Royal Canopy is available, but it's incorrect.:(:(:(:(:(:(:(:(:(:([&o][&o][&o][&o][&o][&o][&o]
RE: CANOPIES
http://www.rcuniverse.com/forum/m_33.../tm.htm#339271
check that out.. and also google vacuum forming table. if you have the ability to make one of these you can build canopies for anything you want after that! Youtube has some videos on vacuum tables as well, I learnt a thing or two from those! <br type="_moz"/> |
RE: CANOPIES
You can look at the fiberglass Specialities web site, if it isn't there you can call them, not all there products are listed on the site. When I'm building from plans I often look at ARFs and try to find the plane I'm building in something close to the same size. You can contact tower and see if they have any parts still in stock for the ARF they used to sell.
