Pull Pull cable
We have put one of these together and we are not pleased with what was provided for the pull cable system. What is a good cable to use
Thanks Bob September Fury |
RE: Pull Pull cable
Just bought this at Tower, nice, adjustable with ease.
http://www3.towerhobbies.com/cgi-bin...LXEVW5&P=7 |
RE: Pull Pull cable
Thanks, I added it to my order
RE: Pull Pull cable
I use fishing leader wire. Stainless with a plastic covering. If I'm not mistaken, it is the same stuff that the RC suppliers are supplying with their setups. Sure looks and acts the same.
Les |
RE: Pull Pull cable
ORIGINAL: LesUyeda I use fishing leader wire. Stainless with a plastic covering. If I'm not mistaken, it is the same stuff that the RC suppliers are supplying with their setups. Sure looks and acts the same. Les |
RE: Pull Pull cable
I also agree, use the nylon coated fishing wire, works very well at a fraction of the cost. You can also use the same keepers the fisher men use, can't remember the name of the gadgets but they look like short pieces of brass tubing that you put the lines through and then crimp. You get a package of about 50 of them in the fishing gear section of most shops. Get the size that is just large enough to pass the line through twice.
RE: Pull Pull cable
ORIGINAL: Rodney I also agree, use the nylon coated fishing wire, works very well at a fraction of the cost. You can also use the same keepers the fisher men use, can't remember the name of the gadgets but they look like short pieces of brass tubing that you put the lines through and then crimp. You get a package of about 50 of them in the fishing gear section of most shops. Get the size that is just large enough to pass the line through twice. "crimps" is what you're looking for. I just bought some 60# test leader cable. No coating on it though. |
RE: Pull Pull cable
I've used Walmart 30lb test solid stainless fishing leader with success. Its like about 100 or 200 feet for a few dollars.
RE: Pull Pull cable
ORIGINAL: cutaway I've used Walmart 30lb test solid stainless fishing leader with success. Its like about 100 or 200 feet for a few dollars. |
RE: Pull Pull cable
You could just use .020 music wire for pull-pull controls, if not excessive slack on the non-pulling side.
RE: Pull Pull cable
"You could just use .020 music wire for pull-pull controls, if not excessive slack on the non-pulling side"
But as soon as you start handling music wire, it starts to rust. Les |
RE: Pull Pull cable
ORIGINAL: bob62 We have put one of these together and we are not pleased with what was provided for the pull cable system. What is a good cable to use Thanks Bob September Fury [link=http://www.sdshobby.net/2pcs-steel-wire-Φ08Ã1500mm-p-2076.html]http://www.sdshobby.net/2pcs-steel-wire-Φ08Ã1500mm-p-2076.html[/link] http://www.sdshobby.net Free shipping too,, takes about 10 days |
RE: Pull Pull cable
I use Control Line cable. Whenever I change my lines for new I save the old for this purpose. Proctor Enterprises sells different sized swages or I make them from brass tube.
RE: Pull Pull cable
Thanks fellows, I went to Wall mart and purchased some 40# steel fishing leader that were braided coated line. Could not buy a roll, so brought leaders, they are 36" long with 4 to a pkg
RE: Pull Pull cable
I like coated kevlar. I use aluminum tube cut to about 3/8" length, crimped with electricians crimp to secure it. It doesn't stretch at all, and its non-metallic.. Don's Hobby in Salina, KS. is where I got it. He also sells whole kits for pull-pull with the coated kevlar. I've bought it in bulk though, and used it very successfully for flying wires on a few different aircraft. The coating is black, and with the coating it looks a tad thicker then a coated steel.. but its very tough stuff, and lightweight, wont' rust.. its almost not of this planet. :)
RE: Pull Pull cable
ORIGINAL: Rodney I would be a little leery of using the solid wire, to much chance of failure should you get solid hit or sharp bend in it. |
RE: Pull Pull cable
ORIGINAL: DGrant I like coated kevlar. I use aluminum tube cut to about 3/8'' length, crimped with electricians crimp to secure it. |
RE: Pull Pull cable
ORIGINAL: cutaway ORIGINAL: DGrant I like coated kevlar. I use aluminum tube cut to about 3/8'' length, crimped with electricians crimp to secure it. So yes.. maybe the grade of kevlar, or the very make-up of the manufacturing of it didn't work for the particular application you speak of.. but I don't think we're comparing apples to apples here. I'm wondering if you have first-hand experience with the situation you're talking about... as its totally different from my first-hand experience.. but I'm not sky-diving either. I wouldn't necessarily knock something just because someone else tried it and it didn't work. How many times did "they" try manned flight before it was successful.. ? If everyone listened to those that weren't successful, we'd all be walking forever. Thats a very extreme example... but ... Henry Ford said "Those that HAVE NOT failed will end up working for those that HAVE failed". Haha.. I guess its a good thing I'm not a skydiver. :) |
RE: Pull Pull cable
If your kevlar has a thickish coating like the stuff on brainded stainless fishing leaders, it's probably fine. It doesn't take much to stop UV rays a sheet of paper thickness can do it.
| All times are GMT -8. The time now is 05:48 AM. |
