RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   RX regulators recommendations (https://www.rcuniverse.com/forum/questions-answers-154/10968733-rx-regulators-recommendations.html)
Brad330l 02-21-2012 04:05 AM
Hi gents,
Are these things just too cheap and nasty or will they handle my 1/5th warbird with lipos 7.4V. I understand they are only 3Amp,,, is this enough? I would be running two separate ones.
What are you all using with this type of thing. I am so sick of my Ni-cads going flat so quick and want to try something different.
Cheers,
Brad
dignlivn 02-21-2012 05:04 AM
RE: RX regulators recommendations
Have you thought about using A123 batteries??
No regulator required,they hold their charge also.
Bob
BarracudaHockey 02-21-2012 06:11 AM
Any good regulator such as Duralite, Fromeco, or others, can handle the load, but as Bob said, A123 is a better alternative.
jetmech05 02-21-2012 08:48 AM
I have been using LI-Ion batteries...Life batteries are a good choice as well.....I use a regulator
It isn't the type of battery that is cauisng you problems so much as it it either the condition of the battery or the capacity in Milli Amp Hours
exeter_acres 02-21-2012 09:32 AM
ORIGINAL: BarracudaHockey
Any good regulator such as Duralite, Fromeco, or others, can handle the load, but as Bob said, A123 is another alternative.
fixed quote ;)
jester_s1 02-21-2012 09:53 AM
+1 on the A123 or other branded LiFe. No regulator needed, all the benefits of a Lipo, and no fire danger. I've been using the Hyperions for about a year now and don't plan on ever buying anything else.
daveopam 02-21-2012 03:21 PM
I am using the reg http://www3.towerhobbies.com/cgi-bin...&I=LXVDB1&P=ML with this battery http://www3.towerhobbies.com/cgi-bin...&I=LXVDB1&P=ML . I just got the set up and have not finished the plane. I like the system because it has so much fail safe built into it.
Posting pics in next post, david
daveopam 02-21-2012 03:22 PM
1 Attachment(s)
These are the pics to match the links.
david
KitBuilder 02-21-2012 05:44 PM
I use 3 cell lipos and regulator b/c my charger doesnt handle A123 plus my servos dont all handle 6+v. The balance chargers and proper charging techniques by the consumer have all but eliminated fire dangers though it is still a possiblity. I gve up nimh last year as well.
Brad330l 02-22-2012 01:44 AM
Guys this is all very good info thank you.
I am so sorry,,, I thought I added the link to the reg I was talking about but I cant see it so maybe I didnt.
Here it is,
http://www.ebay.com.au/itm/230707554...84.m1438.l2648
After looking at the one daveopam linked to Towers I think the one I found looks a bit cheap. I was going to get two and run two systems for redundancy.
So,,, the A123 batteries if you have a pack of two at 6.6 volts is that OK to plug straight into a normal RX?? Is this how I am reading it? They do sound good.
Thanks for all the replys, it really has me thinking. I have never done a lot of research into this subject.
Cheers,
Brad
dignlivn 02-22-2012 05:15 AM
Brad,
I plug my A123 into my Futaba Rx like any other battery. You can
run 2 batteries if you want to.
Bob
BarracudaHockey 02-22-2012 05:36 AM
Exactly, if you have servos with a 6V rating (which is most of them) then just plug it into the receiver and fly.
It needs a decent charger, I use a cellpro, and you have to fly it a couple of times and get an average use per flight, figure out your number of flights, and take a few off as a safety margin.
You can't check them with a ESV.
jester_s1 02-22-2012 07:04 AM
People worry that the LiFe is too much voltage going from 6v to 6.6v, but if you look at the actual discharge curves of them and a NiCd you'll find that the voltages are very close to each other in actual application. I checked mine and found that the LiFe was only .2 volts higher than the NiCd at the receiver when fully charged, and fell in line with a hot off the charger NiCd fairly soon in use. Essentially, an LiFe battery gives you the power of a fully charged NiCd all the way through its practical discharge range. The only negative I've found is that you do have to buy a charger that's made for LiFe batteries, and you do have to use the balancing plug to charge them. That's a small issue if you have the battery in an inconvenient location for balance reasons, but nothing a little extra wire and some solder can't fix.
Brad330l 02-23-2012 02:22 AM
How about these? Two for RX and one for ignition.
http://www.ebay.com.au/itm/200535687...ht_2757wt_1159
Cheers,
Brad
dignlivn 02-23-2012 06:56 AM
Some ignitions work only on 4.8 volts. Great for Rx batteries though.
Bob
Crash-RCU 02-23-2012 01:23 PM
Just get a Castle Ceations 10 amp bec. One end lipo other end plugs into Rx, don't forget the to set the out put voltage (5 or 6v). Should be able to run alot of servos and accessoies with 10 amps.
Brad330l 02-23-2012 02:56 PM
ORIGINAL: dignlivn
Bob
My 3W ignition requires 6v so that is ok.
Castle Creations 10 amp bec looks very interesting as well. So many options.
http://www.ebay.com.au/itm/Castle-Cr...ht_3295wt_1159
Cheers,
Brad
Brad330l 02-24-2012 04:59 AM
So how does this look gents?
http://www.hobbyking.com/hobbyking/s...r_Charger.html
It says A123's.
Brad
jester_s1 02-24-2012 07:12 AM
That's a good charger, but overkill for what you're doing. A 50 watt charger will charge those 2 cell flight packs just as fast for about half the money.
Brad330l 02-24-2012 03:52 PM
ORIGINAL: jester_s1
Thanks for that mate. Yes a bit of overkill. I have just ordered this one https://www.hobbyking.com/hobbyking/...arehouse_.html
and got three two cell packs coming.
I will post here how I go when it all arrives and let you know how I get on.
Thank you to ever one. It's been great.
Brad
TotalWreck 02-26-2012 07:34 AM
These are good chargers. (For charging yourLi-RX-Packs)It comes with all kinds of plugs, even a glow driver adapter for charging, and USB to PC adapter, and a Heat Sensor. Been useing one for a year now. I even charge my Rideing lawn mower battery.
http://www.hobbypartz.com/thac6smbachw.html
Luchnia 02-26-2012 08:39 AM
ORIGINAL: TotalWreck
These are good chargers. (For charging your Li-RX-Packs) It comes with all kinds of plugs, even a glow driver adapter for charging, and USB to PC adapter, and a Heat Sensor. Been useing one for a year now. I even charge my Rideing lawn mower battery.
Can you charge two 2s packs at once? I was looking at the specs but could not tell if it would do two packs at one time. Also does it show you how much is in the A123 cells?
Brad330l 03-24-2012 08:31 AM
ORIGINAL: dignlivn
Bob
dignlivn, you had it nailed mate.
I wired up the new A123's and tested them both together (fully charged) in my Spitfire and no problems at all. I am so happy. I like the simplicity and the gallons of gas in their tank.
Cheers guys,
Brad
Brad330l 03-24-2012 08:32 AM
ORIGINAL: Luchnia
Only one pack at a time mate.
Brad
dignlivn 03-26-2012 06:03 PM
ORIGINAL: Brad330l
ORIGINAL: dignlivn
Bob
Cheers guys,
Brad
Good Flying to you !
Bob
