RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Taurus throws (https://www.rcuniverse.com/forum/questions-answers-154/11247918-taurus-throws.html)
rye 10-01-2012 08:36 PM
Taurus throws
1 Attachment(s)
hi
i am building the Ed Kazmirski's Taurus and i need to know what the throws are for this bird, rudder - ailerions and eleavtor, i am using 2 wing servos and i cut off 8" of the alierions so i know i am going to have to increst the throws on the ailerions,but i need to know where to start,thanks
MetallicaJunkie 10-01-2012 08:49 PM
RE: Taurus throws
1 Attachment(s)
i just eyeballed my throws...i did max out the rudder to get it to knife edge a little better... its a really docile flying plane.... you'll love it....
Gray Beard 10-02-2012 10:16 AM
RE: Taurus throws
I use a degree meter to set my throws and on all my planes I use max on rudder and 10 or 12 degrees up and down on ailerons and elevators. That is a great place to start, then during trim flights I'm able to dial them in the way the plane likes. I do have different starting points for 3-D planes but this is where I start with pattern and IMAC planes.
sledge_78 10-02-2012 01:58 PM
RE: Taurus throws
Rye,
I finished a Kazmirski Taurus last year. I followed the plans for control throws. However, I did use digital servo's and the ailerons were extremely sensitve. I wond up putting exponetial on the ailerons to desensitze the response. That worked very well. My question is why did you reduce the aileron length by 8 inches. You will find this airplane is a terrific flyer. When you cut the throttle on the landing approach it seems like it will never stop flying. Really great and no tip stalls. I will check my set of plans for you to identify the control throws.
huck1199 10-02-2012 02:06 PM
RE: Taurus throws
Is that a K&B .48 on your plane? If so how do you like it?
rye 10-02-2012 04:27 PM
RE: Taurus throws
1 Attachment(s)
hi
i am using two wing servos and made the wing a bolt on so i took out the center section where the wing servo was to make it stronger and added more wing to the ends where i cut off the 8 inches of ailerions
