RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   DsmX Question (https://www.rcuniverse.com/forum/questions-answers-154/11406555-dsmx-question.html)
Thunderhawk09 02-11-2013 07:29 PM
DsmX Question
1 Attachment(s)
Which IsBetter On A Ar600 Spectrum Receiver The Videos Iv Seen Shows The Full Lenth Of Both of the antenna's Being Placed inside the fuse is this fine for the dsmx or would it be better to place the long antenna out the fuse make sure the short antenna is still 90 degrees from the position of the other inside or outside is the big quetion thanks
jetmech05 02-11-2013 08:51 PM
RE: DsmX Question
Both inside
Thunderhawk09 02-11-2013 10:40 PM
RE: DsmX Question
Ok Thanks Thats what i wanted to hear I didnt want it outside of the plane
jester_s1 02-12-2013 06:19 AM
RE: DsmX Question
Putting them outside is really only a factor with a carbon fiber fuselage. The CF is a pretty good blocker of the 2.4ghz signal, so you need antennas outside of it to get good reception.
stevegauth30 02-16-2013 08:17 AM
RE: DsmX Question
Like the guy before me said, on a balsa or foam plane, just keep it inside. 2.4 Ghz is a beautiful thing. Years ago we had to run the antennas outside , or loose your plane. Unless you have a lot of cf in your plane, just run them where it's convenient for you. I usualy run a satellite receiver down to the tail as I'm building the plane. BTW, nice looking decathlon. Who makes it? I just picked up a seagull super decathlon 120, and a DLE 30 to power it. Good luck, Steve
stevegauth30 02-16-2013 08:19 AM
RE: DsmX Question
P.S. the DLE 30 is WAY over powered for that model, but I have other planes for the 30 as well. Just in case you were actually wondering. Lol.
