E-Flite Electric Retrat PCB/Controller replacement?
Hello,
I don't know if this is the correct sub-forum for this. The PCB on the nose retract from my E-Flite 60-120 Retract is dead. The electric motor is working and the mechanical parts are fine. I don't want to spend $90 for a new unit just for the PCB that probably will fail again sometime. So, is there any aftermarket retract controller/PCB that would work, or, any DIY solution for this? Is it possible to use a servo circuit with some mod? The controller needs to run the retract motor from gear down end-point to gear up end-point and also stop if something get stuck or jammed. Maybe this retract PCB could work? I'm also thinking about trying this programable gear door sequencer, which I already have, but adding a servo circuit to control the retract motor signal. I can set the the end points the servo with this module. Any thoughts? |
Have you contacted Horizon? I had an electric Eflite nose gear that would not work properly. I emailed Horizon with all the details (actually took two emails) and they replaced the entire unit for free. I now have the original unit's mechanical parts set up as a tailwheel retract driven by an air cylinder that will be in another model.
Chuck |
I emailed them but did not get and answer yet. If they at least sell me only the PCB it will be great.
Originally Posted by Guijs
(Post 12028190)
Hello,
I don't know if this is the correct sub-forum for this. The PCB on the nose retract from my E-Flite 60-120 Retract is dead. The electric motor is working and the mechanical parts are fine. I don't want to spend $90 for a new unit just for the PCB that probably will fail again sometime. So, is there any aftermarket retract controller/PCB that would work, or, any DIY solution for this? Is it possible to use a servo circuit with some mod? The controller needs to run the retract motor from gear down end-point to gear up end-point and also stop if something get stuck or jammed. Maybe this retract PCB could work? I'm also thinking about trying this programable gear door sequencer, which I already have, but adding a servo circuit to control the retract motor signal. I can set the the end points the servo with this module. Any thoughts? Thanks |
| All times are GMT -8. The time now is 07:08 PM. |
