RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Starting a pusher prop engine (https://www.rcuniverse.com/forum/questions-answers-154/11622075-starting-pusher-prop-engine.html)
tomgreen 09-24-2015 07:04 PM
I am just finishing up on a plan built pusher plane. My question is when starting, is it the standard counter clockwise rotation or is it started clockwise. Thanks for all input.
skylark-flier 09-24-2015 08:30 PM
For anything larger than a reed .049 your engine should turn counterclockwise. That's why they make pusher propellers. They still turn in the proper direction but they push air toward you when you're in front of the engine.
jetmech05 09-25-2015 05:12 AM
The engine has no idea which way it's mounted so it turns CCW.
i know I shouldn't go here......I can't help myself..... Props don't push or pull air
skylark-flier 09-25-2015 12:39 PM
Hey jetmech05! Don't push it! I know you're pulling my leg.
(sorry)
Villa 09-27-2015 09:43 AM
Hi TOMGREEN
I flew a pusher canard with a .46 engine and learned that the engine would overheat on the ground. In the air it was OK. Keep that in mind.
