RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Engine idle (https://www.rcuniverse.com/forum/questions-answers-154/11635243-engine-idle.html)
egrave1 12-29-2016 04:39 AM
Engine idle
I have a ASPF61 engine when I run it right side up it run great and idles great but when I run it up side down it runs great but I can't get it to idle
jetmech05 12-29-2016 05:18 AM
Try a glow plug with a bar. Can't remember if it's called an idle bar or a spray bar
JohnBuckner 12-29-2016 09:43 AM
Yep Jetmech they are called Idle Bar plugs, not all that many out there anymore. Egrave1 Its not real clear that you are using the engine inverted or just now mounted it that way.
Its imperative when using an inverted mount that the fuel tank is lowered in the fuselage to approximately the same tank height to carb spraybar relationship as when the engine is mounted upright. Failure to do this always can cause running problems as well as hydro lock and syphoning problems.
John
egrave1 12-29-2016 09:58 AM
The cal does not allow the engine to be mouted any other way. And what do you mean by using an inverted mount that the fuel tank is lowered in the fuselage to approximately the same tank height to carb spraybar relationship as when the engine is mounted upright.
Steve Percifield 12-29-2016 10:48 AM
Lower the tank as much as you can, and put a glow driver on the engine that will come on , on low throttle, to keep the plug hot... You may still have to set the idle higher than normal as well.
sp
ho2zoo 12-30-2016 02:10 AM
The centerline of the tank should be at the same height as the carburetor. And I am a big fan of glow drivers! Some guys will say "Oh, you don't need that!" or "That's cheating!" but I say, when it keeps my plane from crashing, I'm using it!
jester_s1 01-02-2017 08:12 PM
You shouldn't need a glow driver if the tank height is set up right. Sure, they can make an engine run when it won't otherwise, but it's just a bandaid.
If you can lower the engine in the fuselage to put the centerline of the tank even with the carb's spraybar, you won't likely have any more troubles with your engine. But when you go inverted in a setup that otherwise works, you are lowering the carb in relation to the tank, which increases the fuel pressure going to the tank. It's not a big deal running wide open since most of the fuel pressure comes from the muffler tap then. But the trouble shows up at idle. A way to fix it if you can't get the tank right is to add a Cline regulator, but that's something else to maintain in your system.
jaka 01-03-2017 05:16 AM
Hi!
I agree with Jester! No glow driver is needed on any glow engine if it is set up correctly.
I donīt know if the person asking is familiar with the "tank placement rule" or not but here it goes.
"The tank should always be placed so that the center of the tank is in line with carb intake orrifice when the airplane is sitting horizontally" (means in the flying position with tail up high).
If this rule isn't followed you cannot expect a glow engine to run right.
jaka 01-03-2017 06:29 AM
Hi!
It is also important to choose the correct glow-plug, and that is not using a glow plug with an idle-bar.
Idle bar glow plugs is something of the past (fifties) and should/ought not be used on modern engines if you want good performance! Remember! The problems the questioner tells about is not remedied by using this or that glow plug it's a tank placement problem.
As with all sport glow engines an Enya 3 or OS 8 is a good choice.
Fuel: 5-10% nitro and 20% castor oil or synthetic or a blend of these.
Propeller in this case: 12x6, 13x6 or 14x4 for most planes.
11x8 or 11x71/2 if it's a fast "old school" pattern plane (i.e Curare, Atlas, Blue Bird).
jaka 01-03-2017 06:30 AM
Hi!
Idle bar glow plugs is something of the past (fifties) and should/ought not be used on modern engines if you want good performance! But remember! The problems the questioner tells about is not remedied by using this or that glow plug it's a tank placement problem.
