RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Nose wheel steering setup (https://www.rcuniverse.com/forum/questions-answers-154/11679600-nose-wheel-steering-setup.html)
JacoS 06-12-2020 08:16 AM
Hi all,
First time that I am posting on here.
I need some help with E-Flite 60-120 size 105° retract steering arm setup.
When I retract the gear the aluminium slider (that is supposed to disconnect the steering when the gear is retracted) sort of binds momentarily on its rod which causes the nosewheel to deflect. I can hear the gear motor takes some strain during that time, but it is very brief and the slider then unbinds, slides rapidly to its new position and the nosewheel centres itself.
Is this normal or should the wheel be able to retract without deflecting? I cannot attach a photo yet as I have not made enough posts yet.
TIA
Jaco
scale only 4 me 06-12-2020 11:26 AM
Typically you'll raise or lower that steering push rod so the clevis pivot point is at the same level as the retract pivot point,,, if it's too high or too low you can get that momentary binding,,
good luck
JacoS 06-12-2020 11:41 AM
good luck
Yeah, I have noticed that the position of the pushrod on the slide makes a difference. I can manually move it up or down with my hand, but it will only stay there until I make a steering imput or obviously vibrations will move it to where it wants to be.
I thought of giving the pushrod a slight bend, but since it can pivot on the servo side and steering arm side it just moves back to its original position.
I have tried searching for instructions on how it is supposed to be set up or if someone else has had the same problem, but it seems I am the only one that managed to mess it up somehow:confused:
R8893 06-12-2020 02:09 PM
SO4M is correct about the need for the clevis pin to be on the same centerline as the pivot p[in of the retracts. I suggest you install some sort of a bracket that supports the steering pushrod so that it can't move away from that ideal location.
Chuck
