engine thrust question
I am sure this question has been asked before but here goes. I recently rebuilt a crushed plane and I want to know
how to determine the proper engine thrust angle for this plane. Since I had no plans to go by and I had to scratch build the fuse. from the wing forward I did not figure in any thrust angle into the firewall when I rebuilt it. This palne was a tower voyager ARF and I could not find any plans on it so I gave it my best shot and it turned out pretty good looking however I have not flown it yet. I have checked all the important stuff such as CG and control throws and everything is within range but I had no info on the engine thrust angle. I took a stab at it and put in about 3 degrees of downthrust. (I hope I am reading this right but downthrust is when the engine nose is pointed down so many degrees from level isn't it ?) from 0 level. Map |
| All times are GMT -8. The time now is 06:27 AM. |
