Flaps
I am putting a World Models Super Stunt ARF together. This is my first plane with flaps and I need information on how to hook them up. Hitech RX and Hitech Eclips 7 TX. Can someone give me a quick lesson?
Thanks |
RE: Flaps
Use a "Y" connector so both servos are plugged into the Flap channel.
Dennis- |
RE: Flaps
You can use a strip aileron set up and operate them with 1 servo.
RE: Flaps
Thanks Dennis. The flap channel is what channel?
Thanks |
RE: Flaps
I would use separate servos without the Y-connector so that they can be used as flaperons. If you're going to use two servos anyway, might as well make the most of it.
RE: Flaps
Great and thanks. How do I hook the seperate servos up (what chanels) and how do I set up the TX?
Thanks |
RE: Flaps
I can't help you with that. You have to program the transmitter to mix the two channels. The directions should cover it. If not and you don't get an answer here from someone else, then call Hitec. I'm sure they'll be happy to help. :)
RE: Flaps
Okay. When you mentioned flaps, I assumed you had separate flaps and ailerons on the wing, if so, I'd use the "Y" connector and plug both servos into the flap channel. Not sure which that is on your radio, but likely channel 5.
If you don't have separate flaps on the wing, then yes, you'd have to use "flaperons" and two servos plugged into separate channels. Likely 1 and 5 or 1 and 6, then mix them in the transmitter. Do you have the manual? It should tell you how. Dennis- |
| All times are GMT -8. The time now is 11:12 AM. |
