RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Astro Hog Modification (https://www.rcuniverse.com/forum/questions-answers-154/3226375-astro-hog-modification.html)
flyhi 08-02-2005 11:29 PM
Got an extra Astro Hog wing, already built with recommended dihederal, think 3 1/2 Inch. How feasible is it to cut the wing in half at the joint, cut out wing joiner-main spar and balsa and add new wing joiner-main spar and lower the dihederal so this thing won't float so much on landing? many thanks
tailskid 08-04-2005 10:43 PM
RE: Astro Hog Modification
Cutting it in half will be easy....inserting a wing joiner might be difficult at best.....I think adding some reflex to the ailerons might lessen the glide ratio.....sure would be easier than rejoing the wing halfs.
Jerry
WCB 08-05-2005 09:15 AM
You are going to end up having to pretty much re-engineer/rebuild the wing root to accept the new joiner plate and remove the dihedral.It would probably be easier to just build a new wing without dihedral if you have the plans.
