ENGINE AND PROP QUESTION
Hi!
I have a Saito FA-65 4 stroke and plan on mounting it to a Seagull Decathlon .40 ARF.. What prop would you recommend? Thanks Dave |
RE: ENGINE AND PROP QUESTION
should be recommendations in the instructions.,13-5,12-6.11-7 depends on ground clearence what diameter you can use.
ORIGINAL: av8rdavid Hi! I have a Saito FA-65 4 stroke and plan on mounting it to a Seagull Decathlon .40 ARF.. What prop would you recommend? Thanks Dave |
Hi!
A 12x7, 13x6 or a 14x4W, 14x5N APC Avoid all black MA props like the plague!:D Regards! Jan K |
I used a 12 X 6 Master Airscrew on my last model....Are the Master airscrews the black plague you are talking about?
Thanks, Dave |
To jaka,
That is a bit strong to not use a Black MA with a Saito 65! I have had a Saito 65 with a Black (or dark Gray) MA Scimitar prop,(12X6)AstroHog forabout 10 years + or - 2yr. Not one single problem ever. The Hog is set up as a taildragger. Mic |
| All times are GMT -8. The time now is 02:32 PM. |
