RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   how do you make a engine quieter (https://www.rcuniverse.com/forum/questions-answers-154/3518319-how-do-you-make-engine-quieter.html)
rcmannnnnnnn 11-03-2005 04:03 PM
how do you make a engine quieter, can any one help?
Campy 11-03-2005 04:14 PM
RE: how do you make a engine quieter
The 2 basic ways are:
1. Change the prop. APC props are quieter than MAS props. The pitch AND shape of the prop have a big influence on noise. Also a stiffer prop will be quieter than a more flexable one. (Compare the difference in flexability between an MAS and APC prop )
2. The muffler. The stock muffler is USUALLY the most quiet, however, if you have access to other mufflers try them. Occasionally you will find a different (or aftermarket ) muffler is quieter than the stock one. (JTec upright/inverted muffler is quieter than a stock muffler on an OS 1.60 FX by about 3 db )
campbec 11-03-2005 04:47 PM
Hi rcmannnnnnnnn,
I believe you have some very stringent noise regs in the UK. Campy has provided great advice but local solutions to comply may be on hand through your club?
I would only add that if you have to use a restrictive muffler to meet the required db level it is probably better to go to a larger capacity motor rather than trying to endlessly tweak a smaller capacity motor.
Good Luck,
Colin
sbd-5 11-03-2005 05:57 PM
there is a thread allready on this subject that has more ideas from soft mounting the engine to the use of three bladed props etc.
rcmannnnnnnn 11-04-2005 02:21 PM
thanks
kdc 11-04-2005 08:07 PM
The obvious easy answer is to use a bigger prop to keep the revs down. For example I always use an 11 x 7 Graupner on my Enya40SS or OS40 FP while most people reckon to use a 10 x 6 on a 40.
In UK we are always near someones house so we are more noise conscious.
Is this question from UK or NY NY?
Rcpilot 11-05-2005 10:06 PM
ORIGINAL: rcmannnnnnnn
Shut it off.:D
Sorry, I couldn't resist.
CRAZYRYAN 11-05-2005 10:27 PM
or hand out ear headheadsets to everyone even the people living in the houses!!!:D:D:D;)
