RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Pull-pull system question! (https://www.rcuniverse.com/forum/questions-answers-154/3817423-pull-pull-system-question.html)
Kostas1 01-24-2006 06:01 AM
Hi there.
Can anyone tell me how to setup a pull-pull system on rudder and elevator?
Also please tell me what i should buy and post any pics or diagram!
Thank you.
Kostas
bhanley 01-24-2006 09:44 AM
RE: Pull-pull system question!
Kostas - I suggest that you do a search here on RCU on "rudder pull - pull" set ups and you will come up with a lot of info. It sounds like you are new to this so what will be most helpful is some pictures (which you should find as a result of an RCU search) or , better still, go to the field and look at some of what your buddies have done in their planes. As for what to buy, look at DuBro and Don's Hobby - they both offer pull - pull kits with all that you need (except servo arms...) to do the set up.
Good Luck
touch and go 01-24-2006 10:11 AM
Check out this site for some info re pull-pull systems: http://members.cox.net/bdfelice/Ackerman/ackerman.htm
krayzc-RCU 01-24-2006 06:10 PM
let me know if u dont come across any pic both my dp ultmate and wm hype have pull pull elevators
Campy 01-24-2006 10:28 PM
Go to Alan's RC page http://homepages.ihug.co.nz/~atong/ Scroll down to the second or 3rd group. He has several articles on pull-pull including pictures and diagrams.
sweetpea01 01-25-2006 12:22 AM
also look at www.swbmfg.com
they sell giant scale setups, but if you use one servo the technique is still the same, just take out the bell crank and use your servo as the bell crank.
Biggest thing is the distance of your servo arm must equal the distance from each side of the rudder where the wire attaches. This is to keep the correct geometry.
Kostas1 01-25-2006 01:20 AM
Hi.
Can you upload some pics of your pull-pull setups?;)
Tall Paul 01-25-2006 01:55 PM
1 Attachment(s)
I use this on a 100" flying vee-tail electric..
