RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   One servo, Two elevator halves? (https://www.rcuniverse.com/forum/questions-answers-154/4405742-one-servo-two-elevator-halves.html)
maiden-crash 06-19-2006 05:22 AM
Hi guys,
Is there a possible way to use one servo one two elevator halves?
Any help will be appreciated.
exeter_acres 06-19-2006 07:14 AM
RE: One servo, Two elevator halves?
done all the time in many planes... (mostly smaller) you can put the servo in the fuse and then run 2 seperate control rods back to each half...
or some planes have a torque rod that connect the two halves...
Which plane?
might be able to give better directions if the plane is known
touch and go 06-19-2006 07:58 AM
Gator RC sells an elevator joiner which allows the use of one servo to operate two separate elevator halves.
flyfisher431 06-19-2006 08:30 AM
Try setting it up with control lines and a pull pull set up on both sides like Green RCs Jenny.
see the following
http://www.greenmodelusa.com/Jenny_ARF-6.html
http://www.greenmodelusa.com/Jenny_ARF-5.html
MinnFlyer 06-19-2006 11:24 AM
1 Attachment(s)
You can run two pushrods, or one pushrod that is split at the rear, or just run a single pushrod and join the elevator halves with 1.8" music wire
fstevenj 06-19-2006 11:56 AM
Has anyone done a GP ultra sport 40+ with this setup. The two pushrod approach shown in the planes looks like it could lend itself to a little differential elevator. Is the plan setup ok with two pushrods connected at the server, or should I look at doing something more/different?
sweetpea01 06-19-2006 12:17 PM
Try the MK bellcrank from Central Hobbies.
we use it in pattern planes. They sell two sizes. works great and no worries about differential.
MinnFlyer 06-19-2006 12:48 PM
The way they show in the plans works just fine, but I would add a little solder to that joint just to be on the safe side.
RVM 06-19-2006 10:27 PM
You could also try the DEPS from Central Hobbies too. It's really lightweight.
maiden-crash 06-20-2006 04:55 AM
Wow, never knew it was that simple!
Exetre Acres, it will be done on a small piper cub j3 that im building, length: 32", wingspan: 50"
Thanks guys.
Newc 06-21-2006 07:05 AM
1 Attachment(s)
Here's how I have done it on my 104" PBN Nomad....
