Os fp engines
Anyone know the size muffler bolt a Os 40 fp engine uses? I plan on buying several aftermarket bolts instead of the 2 in a pack OS offers. Thanks
RE: Os fp engines
3mm x 30mm
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCC18&P=7]FP 40 muffler on Tower Hobbies[/link] |
RE: Os fp engines
My old FP40 is fitted with 6 BA bolts. These are replacements but I thought the originals were 6BA.
A 6 BA thread is 2.8mm dia x .53 pitch . An ISO coarse M3 is 3.0 mm dia x .50 pitch So the difference is slight but important. I used longer bolts than standard and used them like studs with a nut, so that the tightening is done by the steel nut on the steel thread instead of in the alloy of the silencer. This is a good trick if the threads have worn in the silencer. Of course if you asked this question it seems that you may not have used a thread locking compound! Even a rubbery type of contact glue can be used if you do not have proper thread lock. |
