RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Robart hinge points and Elmers Probond (https://www.rcuniverse.com/forum/questions-answers-154/489775-robart-hinge-points-elmers-probond.html)
rbeck 01-18-2003 01:56 AM
Anyone used Elmers Probond for installing Robart hinge points?
rbeck
branded 01-18-2003 02:08 AM
Yes.......
sydclement 01-18-2003 02:31 AM
Probond
Rbeck
It works great. Oil up the hindge joint in case a little leaks
in to it.
I use it on foam wings and it really holds great.
Syd
Ted Farmin 01-18-2003 05:36 AM
I've been using RC56 for the robarts since it was suggested to me at a IMAC contest. They won't come loose from vibration as they will with a hard glue. 30% 300 and 1/3 scale Cap with this glue, no problems. Also if any gets in the pivot point it will roll out with moving control surface back and forth.
Jemo 01-18-2003 01:55 PM
Probond poly, works great with hinge points. It fills any voids and on built up surfaces, it forms a nice bead around the inner exposed point.
