RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   CHARGING (https://www.rcuniverse.com/forum/questions-answers-154/5110583-charging.html)
jamie 12-13-2006 09:29 AM
CHARGING
i have been chargeing my planes overnite go out to the field to fly and they are at about 50 % the radio's charge the same and our fine 100% this is in three planes so far havent flew any others to test this........ what could be going on ?????????
Rodney 12-13-2006 02:21 PM
RE: CHARGING
I can not understand your question. Care to clarify?
Kaos Rulz 12-13-2006 02:28 PM
RE: CHARGING
Say What???
cstevenpeterson 12-13-2006 03:23 PM
RE: CHARGING
Are you saying that you have charged three different planes (RX's) along with your TX each time, using the same charger and in each instance the RX's have only 50% of full charge while the TX is at 100%?
jamie 12-13-2006 08:32 PM
RE: CHARGING
yes the last guy got it right i use the wall chargers that cam with the planes 2 are futaba and the other onew is a jr charger just noticed this problem ...... i can quick charge them on my field charger and they are 100% any help ?????????????????
da Rock 12-13-2006 09:37 PM
RE: CHARGING
Your transmitter shows voltage over 9.6V, right? And your receivers show voltage over 4.8V, right?
Is this the 50% difference?
That is normal. Your TX has an 8 cell pack that is twice as many cells as in the RXs. If you hook up the JR set, the TX and RX, and charge them overnight with the JR charger, they should show over 9.6 for the TX and over 4.8 for the RX. The charger that comes with a radio set would fill up the capacity of both batteries at about the same rate.
What amount of charge does your quick charger say it's putting into the packs when you use it?
Flying freak 12-13-2006 10:36 PM
RE: CHARGING
ORIGINAL: jamie
Charge warning if you have a Futaba TX USE THE FUTABA CHARGER, if you have a JR TX USE THE JR CHARGER. I would suggest putting the other brand away were you wont accedetaly grab it making this mistake could cost you internal damage to your tx.
Steven
(please dont ask how i know this)
jamie 12-15-2006 01:43 PM
RE: CHARGING
ok guys i have lost you and me. lets start over the packs in my planes are charging up but not full.. i use a lighted battery checker and it shows when i test them after a all nite charge of 50% thats half what it is supposed to be........ now the radio's or tx charge up fine............... my ????? was why do my rx batterys not charge to 100% and yes they are good battery packs
Kaos Rulz 12-15-2006 01:52 PM
RE: CHARGING
Jamie,
Please provide a little more info. What is the capacity and type of RX batteries? What is the rated output of the wall charger?
joey_snaproll 12-15-2006 04:39 PM
RE: CHARGING
Are you checking the rx battery,through a switch harness or right off the battery conectors.I have had a bad switch and when I tested with my tester through the charging jack in the switsh harness the batteries were low ,disconected the battery from the switch and tested it it was full. Bad switch and harness,changed it ,it was fine.This is one reason people like to run two switches and batteries.Might not be your problem but it is worth a look.If not sure Change it anyway,Really what is $10.00 for a main componit in a $500.00 or more plane.
Joe
jamie 12-15-2006 07:51 PM
RE: CHARGING
thank you all my battery is 600ma the chargers are basic wall charger 4.8 vdc at 50ma . i charge these around 15 hours i think ....... and i will check the switches
Rodney 12-16-2006 11:12 AM
RE: CHARGING
You can not reliabley tell the state of charge by reading the voltage. The only way to know for sure is to do a controlled discharge cycle where you control the current and measure the time it takes to drop the voltage to the cuttoff voltage which is typically 0.9 volts/cell if you want to compare against factory specs. Some chargers like the Triton, Hobbico Elite and several others allow you to set this up and do it automatically. If you are charging at 0.1C for 12 to 16 hours, you can be sure that the batteries have obtained all the charge that they are capable of. Check out www.rcbatteryclinic.com for some good info on the care and use of all types of batteries.
