RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Nitrate Dope thinner (https://www.rcuniverse.com/forum/questions-answers-154/578611-nitrate-dope-thinner.html)
Toddly1 02-23-2003 09:49 PM
I am preparing to cover my latest model (an old RCM Sportster) with Sig Coverall. But I'm not sure what or how much thinner to use. I have read that Acetone or mineral spirits should be used. Which is correct?
Thanks in advance,
Toddly1
big max 1935 02-24-2003 12:33 AM
Use Acetone or a high grade lacquer thinner. Mineral spirits are for enamel type paints. Thin it just so it brushes easy, if spraying probably close to 50% .A lot depends on how thick your dope is to start with. I have some that is like tar,WWII Army surplus!!
>>>>>>>>>>big max 1935>>>>>>>>>>>>>>>>
jettstarblue 02-24-2003 08:06 PM
MEK is the only thinner I have used succesfully with dope. Laquer thinner and acetone work with various results.
Available at your local hardware store.
Jetts
Walter D 02-25-2003 12:24 AM
Home Depot lacquer thinner works fine, but you can always go to an automotive paint store or supply store for aircraft and get the good stuff.
jettstarblue 02-25-2003 02:15 AM
Hey guys,
I've got a question while we're at it here. I once tried to thin dope with laquer thinner, and it turned to a cottage cheese like consistancy. I am not doubting that you guys had luck with it as thinner, I just wonder if anybody might tell me what may have happened. I have always used MEK with good results, and never did try laquer thinner again. I may now as it's evaporation rate is slower than MEK. Thanks.
Jetts
big max 1935 02-25-2003 08:48 AM
Old body shop owner told me to add thinner a little at a time as sometimes he said it would "shock" if added too fast. Who knows? I have always used hi-grade or dope thinner. big max 1935
Walter D 02-25-2003 01:53 PM
Sure the beer can wasn't sitting next to the one with lacquer thinner!?
Like Bigmax says, a little at a time does the trick, and always stirring the contents at the same time.
1/4 flyboy 02-25-2003 02:17 PM
Laquer thinner works fine just keep stirring it till it turn perfectly clear again just look at it and make sure it is blended in, or you can use the Sig thinner at $9.00 a quart. at that I am willing to stir a little. good luck
jettstarblue 02-25-2003 04:43 PM
1/4 flyboy, thanks, Ace hardware thinner is a lot less.
Big Max, thank you, I tried it mixing slowly, and it worked fine. I did just "dump in" the thinner when I tried it before.
Walter D- I don't know how your beer can would be sitting next to my thinner on my work bench. Are you sure your thinner wasn't a little to close to your beer can? :bananahea
Jetts
Buz^ 02-25-2003 05:36 PM
TURNED TO COTTAGE CHEEZE?
Sounds like you accidentally used LATEX PAINT REDUCER :rolleyes:
jettstarblue 02-25-2003 05:45 PM
Alright, UNCLE-UNCLE!!!
If you mean water, no. Thanks, I got my answer. I was just pouring it into the dope to fast. When I use MEK i don't have that problem. HOWEVER MEK has a much faster drying rate, so it is not suitable for unexperienced dopers.
Jetts
Toddly1 03-03-2003 02:15 AM
Thanks to all. I used plain old True Value Hardware Laquer thinner and it work fine.
Toddly1
Jim Finn 03-07-2003 11:21 PM
I have found that laquer thinner curdels colored dope but works fine in clear.
monocoupe 03-08-2003 05:10 AM
Nitrate Dope Thinner
I've always just bought real honest to goodness dope thinner by the gallon from an aircraft supply house. It always works, and the cost by the gallon isn't bad at all...of course, it's been a while since I've bought any. ;)
Cheers, Nigel
cublover 03-09-2003 03:36 AM
i use methel ethel keytone..."I think i spelled that right"..LOL...you can get it at the hardware store...have a good one..Rod
