Engine help
I just Bought a Saito 125 for my Showtime and have tried to start the engine but the exaust seems to be coming from the carrburator hole instead of muffler. Any suggetions?
showtime9023 |
RE: Engine help
a
RE: Engine help
did you buy new or used.most larger 4 strokes are started by turning the prop counter clockwise till compression is felt then hook up the glo driver and a quick flip counter clockwise and it should backfire and start running in the correct direction.If you bought the engine used,the valve timing may be messed up.
RE: Engine help
Sounds like your intake valve is to tight or not closing fully.
RE: Engine help
I bought it new. thanks for the help I'll have to do some tinkering with it. I have all the time in the world sine out clubs leased land was just sold and we now have no where to fly.
Showtime9023 |
RE: Engine help
if you bought it new and it is not right return it and have it fixed under warranty
| All times are GMT -8. The time now is 12:31 PM. |
