Engine Thrust
1 Attachment(s)
I have a STAUDACHER 60 ARF, I am ready to mount the motor but I didnt notice any thrust angle on the firewall. Isn't this just about necessary?
Any suggestions on how much I should add if any.. Thanks in advance |
RE: Engine Thrust
If the instructions dont say anything about it I wouldn't worry about it. I just finished my 2nd Goldburg Ultimate ARF. you dont really notice the thrust angle until you install the cowling
RE: Engine Thrust
2 Degrees is a good starting point. You can take a ruler on end and see if it has any right-thrust built in. If it's not obvious, then it doesn't have any.
RE: Engine Thrust
Hi!
0 degrees on everything (Wing, tail and engine) if its a low and mid winger. |
RE: Engine Thrust
Here's a guide to see if you need any side thrust.
Fly model away from you INTO any wind; Pull to straight vertical at normal cruise speed. DO NOT use rudder A. Model continues straight up = No Adjustment B. Model yaws left AFTER line established = Add right thrust C. Model yaws right AFTER line established = Reduce Right thrust Again, 2 degrees is normal for your typical low-wing sport model. Your milage may vary... |
RE: Engine Thrust
Learn to fly the plane with rudder. Full scale airplanes do not normally use any additional down or right thrust. I quit building in offset thrust years ago, and have become a better RC pilot. If you feel that you must use right and down offset, 2 or 3 degrees is a good place to start. Again, if you will learn to fly with the rudder and learn throttle management, you won't need it.
Bill, AMA 4720 WACO Brotherhood #1 |
| All times are GMT -8. The time now is 05:54 PM. |
