RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   How does the Y harness with reverse work (https://www.rcuniverse.com/forum/questions-answers-154/6326599-how-does-y-harness-reverse-work.html)
DerekChurch12 09-04-2007 01:01 PM
I am finishing up on my first attempt at building a P-51. The problem is this. My receiver has only one imput for the aileron so I had to use a Y harness with a reverse function. I have messed around with it some but found that the ajuster will move the servo but it wont return back to its position. Does anyone know how this works? I am using it with a JR transmitter and receiver. Thanks in advance for any help.
Derek C.
RCKen 09-04-2007 02:12 PM
RE: How does the Y harness with reverse work
1 Attachment(s)
For ailerons you should use a regular Y-harness, not a reversing Y-harness.
Refer to attached diagram for connections to the aileron servos.
Ken
bruce88123 09-04-2007 07:18 PM
ORIGINAL: DerekChurch12
Derek C.
First, Receivers have outputs not inputs. The input is called an antenna.
I guess you mean the adjuster in the reverser moves the center on the related servo but what do you mean it won't return to its position? What position?
Did you buy a reverser for a JR?
http://www2.towerhobbies.com/cgi-bin...&I=LXAFN2&P=ML
A Futaba reverser will not work.
jetmech05 09-04-2007 07:29 PM
ailerons dont require a reversing Y...
ChuckW 09-04-2007 08:01 PM
Like everyone has said, just get an inexpensive standard Y harness for your ailerons. The reversing Y is mainly for things like dual elevator servos when your radio doesn't support it.
DerekChurch12 09-05-2007 07:28 AM
Thanks for all your advise. Thats what I did and I found that I had made a CARELESS mistake in mounting the servo. Thats why they were moving the same direction.
Bonified Wingnut 09-05-2007 10:42 PM
Speeking of y harness's where is the cheapest place to get them? Tower wants like $ 9.95.
mimhoff 09-11-2007 09:13 AM
Bonified Wingnut--
I use connectors, wire, switches etc from:
http://www.maxxprod.com/mpi/mpi-4.html
They are very reasonable and I believe to be of good qaulity.
Tired Old Man 09-13-2007 05:55 PM
Buying a higher end Wye harness is not expensive. Better quality costs more. The Tower price is one that I would consider cheap.
