RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Fail Safe Settings (https://www.rcuniverse.com/forum/questions-answers-154/7302756-fail-safe-settings.html)
aa2dd 03-29-2008 07:10 PM
Fail Safe Settings
Other than throttle off, what are the recommended failsafe settings?
Bruce
Campy 03-29-2008 07:16 PM
RE: Fail Safe Settings
Set the controls for a gentle circle
daveopam 03-29-2008 09:22 PM
I put everything centered and throttle at idle. If you have the throttle off and you get control back it could cost you the plane. I don't do the slow circle because my flying is wild. The plane is inverted as much as up right. If I have a little down Elev and the plane is inverted, well you know.
David
bbbair 03-29-2008 10:23 PM
It depends on many things not the least of which is what plane you are flying.
Slow circles are OK of you have a Cub and expect it to land itself in a farmer's field somewhere. BUT if you are flying a Jet with the throttle to the firewall - it's a different story. [:o]
I knew a Jet Jock that had his fail safe set for throttle off and a snap roll - the idea was that IF the plane is out of control - bleed off as much energy as possible NOW! Before it goes too far and before it hits anything... [&o]
He considered it an intelligent thing to do rather than have a long range missle ... [sm=frown.gif]
I gave him full marks for the ability to write off the AC before it could hurt someone. [sm=thumbs_up.gif]
GRANT ED 03-30-2008 06:38 AM
I have mine set.
Throttle to idle
aileron and rudder to neutral
Elevator pos hold.
