Flaps/flaperons down question
I've got several planes that I'd like to program flaps and flaperons into my radio. Quesion is, what kind of flap/elevator should I program in to keep them level while descending?
Up or down elevator? |
RE: Flaps/flaperons down question
You would use down enevator. I would start with about 5% and work from there. The exact amount will be different for each plane and flap setting.
With flaperons watch that you dont tip stall......
Steven |
ORIGINAL: Ed_Moorman You would use down enevator. I would start with about 5% and work from there. The exact amount will be different for each plane and flap setting. |
I just programmed the flaperons on my Dynaflite Spitfire and there is a significant downward pitch with the flaperons engaged. My Byron Corsair (with separate flaps) just mushed straight ahead. It all depends on the plane. Myself, I would rather just use the elevator as needed because conditions are never going to be the same.
I engaged my flaps on my Ultrastick and the plane immediately pitched nose up and stalled so I landed it and put in 5% down flap/elevator mix and tried it again. Still pitched up so in went 15% down flap/elevator mix which seemed just right with 20% throttle. Thanks for the advice guys
| All times are GMT -8. The time now is 03:13 PM. |
