RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Negative Expotential (https://www.rcuniverse.com/forum/questions-answers-154/768586-negative-expotential.html)
flyhi 05-13-2003 01:16 AM
What exactly does 28%, for example, negative expotential on ailerons mean? does that mean up or down? thanks.
Steve Guinn 05-13-2003 02:30 AM
Exponential either increases or decreases the sensitivity of the control stick near the centered position.
With -28% Expo, the stick is less sensitive and you must move it further to obtain the same control deflection that would be seen with no Expo.
fishgod 05-13-2003 03:18 AM
Unless of course you are flying with a JR transmitter. With JR negative expo makes it more sensitive around center. Dont ask me how I know.
Jemo 05-13-2003 09:18 AM
If you use Futaba, you enter a Minus number to decrease sensitivity in the center, and a plus number to increase it.
With JR you use a plus number to decrease sensitivity and a minus number to increase it..
All expo works the same. If you use the correct settings.
glowplug 05-13-2003 01:26 PM
LMAO fishgod....why do they make things so complicated??
Mike
OldRookie 05-13-2003 02:38 PM
If you ever forget which way + or - to go for your radio brand, just put in a positive or negative 100%. You will know right now which way to go.
Greg
Geistware 06-15-2003 01:22 AM
I just tried to use 100% positive expo on a futaba. I would have to be a Grand MAster with a transmitter to be able to fly it like that!
David Cutler 06-15-2003 02:20 AM
As an extension to this thread ..
What, exactly, is the percentage exponential, a percentage of?
It can't be the extent that the curve is 'flattened', as 100% would act like a sudden switch to full deflection (if positive) or not at all until the extreme position, (if negative) when it would suddenly give full deflection.
-DC
