Powerbox sensor switch
Hi
I am currently building a Composite ARF Extra DA 50 MTW canisters etc but my question is to do with the radio set up. I am using two JR 8511 and 3 JR 8911 servos i wanted to use a Powerbox Sensor switch running two LiPo' of about 2amps each battery. Is the powerbox sensor switch ok to use in this setup or should i be considering a powerbox professional for example? I want to keep the weight down but am unsure if the sensor switch alone is the way to go??? |
RE: Powerbox sensor switch
Frazerrees,
When you hook up your PB sensor what is the voltage readout at the receiver. I've been using one for a while now and its great on 50cc planes. jds |
| All times are GMT -8. The time now is 09:55 AM. |
