RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Prop Conversion? (https://www.rcuniverse.com/forum/questions-answers-154/797662-prop-conversion.html)
outflying3d 05-23-2003 05:54 PM
Prop Conversion?
Does anyione have a chart to convert a 2 blade (apc 13 x 8) to a three blade (perferably apc) prop?
Any help would be great!
Curt
tailskid 05-23-2003 06:38 PM
Prop Conversion?
I don't know of any chart, but the general rule is to drop back one inch in diameter and add one to the pitch......
Jerry
DBCherry 05-24-2003 02:30 AM
Prop Conversion?
Tailskid,
Doesn't that rule apply when changing sizes between two bladed props?
I'd always heard that to convert from 2 to 3 blades you only drop an inch in diameter. (ie. 2 blade 13 X 8 = 3 blade 12 X 8.)
Dennis-
Steve Lewin 05-24-2003 07:59 AM
Prop Conversion?
The real rule for equivalent power is to reduce the prop diameter by 10% and leave pitch alone.
By a bit of good luck 10% = 1 inch for the most common 10/11" props.
Generally you can't do it very accurately because there is only a limited range of 3-blade props available. In this case 11.5 x 8 would be about ideal, if you could find one.
Steve
Jemo 05-24-2003 11:29 AM
Prop Conversion?
Here's a guide
http://www.zingerpropeller.com/_2_blade_.htm
