Capability of DYNATRON starters?
This summer I'll be flying a couple of big planes. They're equipped with a 3000 Supertigre and a Saito 180. Even with a fully charged battery my regular Sullivan starter does not have enough oomph to kick these over. I see Sullivan Dynatron starters come up used once in a while on the FSW forums for around $40 and was giving them some thought.
Anyone have any real-life experience with Dynatrons and are they capable of starting these engines with a 12v battery? Sullivan web site says they'll start up to a 40cc but I really don't believe manufacturer's claims since I had a Hobbico 180 starter that had a hard time with 91s. Thanks |
RE: Capability of DYNATRON starters?
The problem is most likely your battery not being able to provide enough amps. Power is watts, IE volt x amps.
I can start my Saito and magnum 180's with a trusty 30 yrs old Sulivan starter. A model shop gell cell is insufficient. I use a yard tractor battery or hook to my car via jumper cables. Wind the prop back to compression before applying the starter. Another trick is to close the throttle completely, spin it up then open to low. |
I have their 60 dollar heavy duty model, easily starts 25 cc weedwackers on a 12 volt lawnmower battery, and when its hooked up to 24 volts (2 batteries) it easily starts my 46cc motors...
Mine will turn over, & start a G-38.
the Sullivan Dynatron is a good starter..rated at 12 to 24 volts at 100 Amps max......I was using a car jump start battery and my dnyatron would start my OS 1.60...unless it was cold...I went wih a Makita drill battery at 18 volts..now it spins my 160 with gusto
There was a guy on here with one that he started his B29 ZDZ 80's with but it had a Miller speed reducer on it and he was running 24 V
http://image2-4.rcuniverse.com/e1/fo...52/Jh16564.jpg |
That setup looks like a few hundred $ along with two men and a dog helping!!!!
It's a one handed affair and I think all total it is around 275 including the Dynatron starter
He's a quote from Mac Hodges the owner The Miller Dynatron unit does not have to be a two hand affair. I have one that I put together that I have been using for over 10 years and it is a one hand operation that is easy to use and will start anything from a 20cc to over 150cc engine. First, I join two 12 volt 7 amp. gell cell batteries with a couple of strips of thin double sided tape. Then using double sided tape, I mount two 2 1/2" muffler clamps on top of the batteries. I slit fuel tubing and put over the edges of the clamps to protect the starter. I then strap the starter to the batteries with a couple of large plastic tie wraps. But before mounting the starter, I remove the strip switch and add wire to connect to the added switch and bracket. This places the push button switch conveniently under your thumb for easy one hand use. And then wire in series for 24 volts. I sell the switch and bracket for $20. The Miller reduction unit is $125. I sell the complete starter for $275. |
Now I see the thumb starter button.........I used to have one of those on my 38 Dodge.
ORIGINAL: foodstick I have their 60 dollar heavy duty model, easily starts 25 cc weedwackers on a 12 volt lawnmower battery, and when its hooked up to 24 volts (2 batteries) it easily starts my 46cc motors... I just gotta get the Dynatron. |
I have a friend with a couple Hi-Torks and he got a 40cc gas engine. Hooked up 24 volts to a HiTork. It started the 40cc engine but the contacts in the starter switch welded themselves shut and the starter wouldn't shut off.
that is true on the starter switch contacts.ine have stuck a few times.
We use the Dynatron with two 12 volt lawn mower batteries hook in series and it will zing A G-45 with ease. It does tend to get hot if your engine doesn't fire up after a couple of tries though. Due to the weight of the two batteries we installed them in the bottom part of a plastic rolling tool box. I use one of these boxes for my flight box set up for glow planes. The easy answer would be to buy a starter with the gear system or make a starter yourself. I used one made from a Toyota Truck starter with a small 12 volt battery for starting my G-62s all the way up to a Fox 100 twin. It was cheap to make but heavy. There are several ways to start the bigger engines, I went back to the spring starter on the G-62 I have now, with only one big engine I can't see myself spending the money or hauling a heavy starter around.
