RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   4 Stroke jam nuts (https://www.rcuniverse.com/forum/questions-answers-154/9388657-4-stroke-jam-nuts.html)
dignlivn 01-05-2010 08:54 AM
4 Stroke jam nuts
I need jam nuts for my OS 70 and Saito 82.
Would I have any luck at Lowes ?
Bob
bgfireman 01-05-2010 08:59 AM
RE: 4 Stroke jam nuts
dignlivn
Sure you would. There or any other hardware store with a good selection of nuts and bolts.
Alan
Ed Smith 01-05-2010 09:21 AM
I am guessing the locknuts are for the screws holding the engines to the mount.
Use the "Nylock" lock nuts. They will not vibrate loose. I purchase mine from an industrial fastener supplier.
Ed S
timcat26 01-05-2010 09:40 AM
I don't think you're going to find the true factory style Jam nuts with the sleeve on the end to fit inside the larger nut at Lowe's or Home Depot. That said, simply adding a second regular nut for safety to avoid throwing props should work and this should be available at any hardware store.
dignlivn 01-05-2010 10:29 AM
ORIGINAL: timcat26
That is what I was thinking also.
Bob
Wonder 01-05-2010 04:30 PM
I fly a lot of 4 stroke engines and have never used a jam nut or lost a prop yet.
Most people that throw props are over propping the engine and using to high of nitro to compensate.
Tim
dignlivn 01-05-2010 11:20 PM
wonder,
Thanks, but I was not throwing props.
Just thinking Saftey,
Bob
Gray Beard 01-05-2010 11:25 PM
Most any good hobby shop that sells the engines usually have the extra nuts with the machined taper in stock. If not then tower or Hanger 9. If you are using a spinner then the spinner addapter nut acts as the jamb nut.
fredscz 01-06-2010 12:36 AM
Your Lowes and other hardware stores are sure different than the ones I have access to. If your needing the lock nuts used on the prop shaft, you will need metric nuts. Saito nuts are easiest to obtain right from Horizon and the OS's can be had from Hobby people if you can find the size and buy the magnum equivalent.
fred
Gray Beard 01-06-2010 01:20 AM
I have never found them in a hardware store either but I have one great hobby shop!!
aerofly0610 01-06-2010 02:28 AM
Order a bunch from a hardware site like http://www.mcmaster.com/
carrellh 01-06-2010 04:39 AM
I would try to get hardened steel rather than standard hardware grade.
Lowes web site only lists one M7 nut. At 68 cents for 5 nuts they are probably not hardened steel. The store hopefully has a better selection. Metric high strength is called Class 10 Alloy Steel.
They may or may not have the 5/16 nuts in Grade 8 or Grade C. According to McMaster-Carr, grade 8 and C are equivalent.
If Lowes doesn't have what you need, try an auto parts store. Ask a counter guy because they often have bins in the back and the selection/price is usually a lot better than the little packages hanging on the racks.
safeTwire 01-06-2010 09:34 PM
http://www3.towerhobbies.com/cgi-bin...6687&search=Go
http://www.horizonhobby.com/Products...rodID=SAI56110
