85"yak recomended servo arms?
I used the recomended airwild servoarms and the dubro horns.On my ailerons the push rods from servo arms to horns do not line up at a 90 degree angle not even close what do i do? when u pay good money for these arfs this kind of stuff is irritating.............
AZ
RE: 85"yak recomended servo arms?
Get a good plane like a
75cc Yak 54 ARF-QB
Yak 54 ARF-QB Quick Build
Aeroworks is proud to introduce their New line of QUICK BUILD Series Aircraft
Designed with the customer in mind to provide the highest quality, light weight construction and fastest build time possible.
Aeroworks has Raised the Bar. The QB Series is top quality in both design and performance that will set a new standard for ARF aircraft
With the Yak 54 unbeatable stability and precision flight characteristics it is certain to please both the beginner as well as the advanced competitor
Designed for both precision and 3D style flying this plane is sure to out perform all other aircraft.
The Yak 54 was designed from the ground up to be a top performing aircraft. Generous control surfaces and an awesome power to weight ratio make this a plane you'll want to fly every visit to the field!
SPECIFICATIONS
Wing span 94 inches.
Wing Area 1650 sq. in.
Fuselage Length 81" (Rudder to front of cowling)
Fuselage length 86" ( Rudder to front of spinner)
Weight 21 to 22 lbs
Engine 75 cc
Radio 6 Channels minimum
FEATURING
Strong Light Weight Construction
Complete and Detailed Instruction Manual
Painted and Pre mounted 7075 Aluminum Landing gear
Complete US Standard Hardware Package Included
Machined aluminum engine stand offs included
6061 T-6 Anodized Aluminum Wing Tube
6061 T-6 Anodized Aluminum Stab Tube
Professionally covered in ULTRACOTE
Clear Ultracote provided for sealing hinge gaps
Pre-Hinged from factory (Ready to Fly) No gluing
Two Servo Wing
Large control surfaces double beveled for maximum throw
Custom Throw Meter provide for exact measuring of control throws
Pre Mounted Fiberglass Cowl and Wheel Pants
Pre Mounted and Tinted Canopy / Hatch assembly
Canister & Pipe READY!
Pre installed and fuel proofed engine box
Two Fuel Tanks provided for engine and smoke
Laser cut engine mounting templates provided
Custom Vinyl Decal Set
8 to 10 Hours assembly Time
75cc Yak 54 ARF-QB
SPECIFICATIONS
Weight 21 to 22 lbs
Engine 75 cc
FEATURING
Two Servo Wing
