Is This Good !!!
CA
RE: Is This Good !!!
Consider the weight of the Fuji motor.. if it's close to the same weight as a DA 50, then it
should work. Is the horsepower rating the same, or less? More? These planes are not
designed to have weight added to them in order to balance. It is much better to balance
with what equipment is required. Rudder servo and battery locations are optional for
balancing.
I suggest you read thoroghly, the build threads here on this forum to gain further knowledge
of giant scale flying, in particular, the Yak 85.
Gerald
ORIGINAL: dubai_UAE
hi >>
what U Think If I But 65cc fuji engine In yak 85 ...
I should But wihgt In teil
hi >>
Note this is the QQ 85" not the new 86" which has a longer nose and is lighter.
Mike
My Feedback: (73)
Actually planes are sold out already! If you didn't have your name on the list you may want to do so ASAP to have a chance of getting one should some of the guys ahead of you fall through.
Thank you,
Reza
Thank you,
Reza
Ah, i think Molly had me in the list. I really need to know if i was there or not because i've been lingerind around here for like 3 months hahaha, thanks for letting me know.
