86" canister question
RE: 86" canister question
Mine didn't want to stay in place until I roughed the mating surface for the teflon connector on the header. In other words, yes, mine rotated a few degrees and also moved backwards.
I have used worm drive clips on the teflon tubing not the normal expansion ring type, and the mod in the photo below, never moves now supprisingly enough, its just plywood and a heat proof gommet.
Incidently this is the 85" that I modified myself to take a cannister so take no notice of the state of the inside of the compartment, that is not how QQ supply the 86" much better workmanship than mine.
Mike
Mike
