QQ Yak 69" former in pull-pull cable slot
Old 12-08-2008, 03:51 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Default QQ Yak 69" former in pull-pull cable slot
Do you need to cut the former in the rudder pull-pull slot? Will this weaken the fuse it it is cut? The instruction manual is not clear about this, among other things, and could do with improvements
rajul is offline
Old 12-08-2008, 10:07 AM
Rezagh
My Feedback: (73)
Default RE: QQ Yak 69" former in pull-pull cable slot
That slot is for you to pass the cable through. You should not need to cut the former.
Rezagh is offline
Old 12-08-2008, 10:10 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
The question is will the cable rub with the former? I have not routed my cable yet, but should the cable be in front of the former or behind it?
rajul is offline
Old 12-08-2008, 10:16 AM
Rezagh
My Feedback: (73)
Cable should be in the slot not behind the former. Cable is coated should not be a problem!
Rezagh is offline
Old 12-08-2008, 10:21 AM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
The former is roughly in the middle of the slot. How did you route your cable, in front or behind the former (in the slot of course)?
rajul is offline
Old 12-08-2008, 01:15 PM
kochj
I think he said in front of the former....
kochj is offline
Old 12-08-2008, 07:43 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
So, that means going through slot A in the pic. Can any Yak 69" owner confirm this? This should have been included in the manual. Thx
rajul is offline
Old 12-08-2008, 08:29 PM
Rezagh
My Feedback: (73)
That is correct, it goes through slot A!
Rezagh is offline
