JR XP662 help
JR XP662 help
I have acquired an old JR XP662 transmitter that I would like to use . I have two different JR receivers but neither will work with this transmitter, Can anyone tell me which receivers are compatible ?
Match the crystal (channel) noted on the back of the radio. That transmitter channel needs to be the same number as the receivers and they need to be FM.
You can find auto shift receivers that work with both positive shift and negative shift receivers, (Hitec) and synthesized receivers that lock on to any frequency and any radio that uses FM modulation.
Corona made a good synthesized receiver and you can find it here - https://www.ebay.com/itm/186268549683
These are rock solid in connectivity with any FM radio.
