what type of motor is this?
That is an engine, not a motor.
It is a glow engine with slide carburrettor and rear exhaust, looks to be small, so around .12 cu/in capacity. Not sure of the brand/manufacturer.
Very unlikely that you would be able to fit a pull start to that engine as the crank shaft would probably be different......and that is if they ever made a pull start version....and if you could find one.
If the thread was titled "Who makes this engine" and you put it in the engine section of the forum (link below), you may get more luck.
http://www.rcuniverse.com/forum/car-...s-engines-269/
