Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC 1/8th Scale Buggies
Help: convert two 2S batteries to one 4s battery setup >
RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Old 11-25-2016 | 07:43 PM
Default Help: convert two 2S batteries to one 4s battery setup
I just recently found an Ofna lx2e RTR that I bought years ago and never opened. I'd like to go with a single 4s pack. The ESC is set up for two packs(2 deans leads). What kind of adapter would I need? Also, what size 4s battery would I have to go with? Thanks in advance.
Old 11-26-2016 | 09:27 AM
RustyUs's Avatar
You should see two main wires coming from ESC (one positive & one negative)...use only those two wires to connect to the connector of your choice. That extra jumper wire and connector is not needed when using one 4S pack.
Name:	2 packs.JPG
ID:	2191290   Click image for larger version
Old 11-26-2016 | 10:01 AM
RustyUs's Avatar
If you don't have a soldering iron, then a 2 Female to 1 Male Deans adapter is needed I guess.
I would highly recommend soldering the ESC to your needs rather than using an adapter. Hobby shop nearby?
Old 11-26-2016 | 12:40 PM
Propworn's Avatar
Are the two leads to the esc wired in series or parallel?
Old 11-27-2016 | 07:00 AM
The esc is setup with the battery packs in series just like the 1st picture Rusty posted. Personally I'd break out the soldering iron and get rid of one of the connectors but you can buy/create an adapter as well.
If you want to maintain the ability to run 2 packs, simply get a female deans connector and solder a single piece of wire to both leads of the connector to create a jumper. Plug it in and now that connector is bypassed allowing you to run a single 4s pack. Unplug it and you can use two packs again. Found these images by googling "deans jumper" so I assume you can find them on eBay or whatever using the same terms.
ID:	2191414   Click image for larger version
