HELP! Hyper 7 TQ Engine Problems During Break-in
Hi guys,
Sorry for the long post that's coming up.
Haven't played with Nitro care for at least 10 years and just bought a brand new Hyper 7 TQ Buggy with the Hyper 21 3-port engine for my son to try and introduce him to the hobby. It's been a nightmare trying to start the engine to do the break-in process. My son hasn't been happy about it and I'm worried it's going to put him off the hobby even before he's started.
Was going through the break-in process of idling the engine for 3 tanks and then 2 tanks of easy driving, as per the manual that came with the car. Anyway, before even getting the engine started on the first tank, we broke the pull start, it wouldn't recoil. It broke because of the hard pulls, especially with the tight pinch of the piston and sleeve. Took the pull start off the engine to have a look and the spring popped out and it was a nightmare trying to put it back in. So decided to remove the spring and the cord winder and just put the cover back onto the engine and plug up the hole where the cord goes through. I had a starter box, so decided to use that to start the car. Tried numerous times to start the engine, but it wouldn't start. There would be times when the piston would get to TDC and get stuck due to the tight pinch of the new engine, so I would turn the flywheel by using a screwdriver and prying it from the bottom to make it turn as it was too tight to just use my fingers. Of course, each time this happened, it would slightly damage the flywheel. the tightness was there even when I removed the glow plug. Anyway, did this a few times and eventually the engine started and we left it idling for the full tank.
Once the tank was almost empty, we stopped the eninge and left it to cool down for 5 minutes, making sure the piston was at BDC and "loose". Go to start it again, same thing happens. It would crank a little and then get stuck at TDC and have to pry the flywheel to loosen it and then tried starting it on the box again. Did this again and again and it would get stuck again and again. During my attempts to start the engine, I would remove the glow plug to release the compression, heat up the engine with a heat gun and try to crank the engine, but it would do the same thing of getting stuck at TDC. Even running the engine for one tank, it didn't seem like the tightness had reduced. So kept prying the flywheel to loosen it, then trying to start it on the box. Eventually after about an hour of trying, it finally started and we idled it for the second tank.
Time for third tank and what do you know, the same thing happens. Spent another hour doing what we have been doing just to try and crank the engine and start it. While during this time with all the prying of the flywheel, most of the small teeth on the flywheel have broken off from the the force required to turn it using the screwdriver. Eventually it started and I'm thinking surley it will be all nice and loose by now after three tanks, so I can just turn it with my fingers. NOPE!
Going for the 4th tank and again the same issues. This time it seemed like the tightness is even worse! with all the prying, the flywheel pretty was much shot and doesn't have any teeth left in the areas that corresponds to the piston's TDC. I even broke two screwdrivers trying to pry it and tunr it. I removed the engine from the car to turn the flywheel with my hand. It required alot of force to turn it and eventually it got loose, so I'm thinking it should be ok now. Put it back onto the car and try to start it and it happens again and the piston gets stuck at TDC with no way of being able to turn the flywheel without taking it off the car again. At this point I'm p1$$ed off and gave up.
Has anyone had this problem before and if so, how did you sort it out? I'm really stumped on why the pinch is so tight. I know new engines are tight, but not this tight, especially after 3 full tanks of idling. I've given up on trying to sort it out and pretty much thinking it's a $500 dud that I bought. The unfortunate thing is my son has waited so long to play with it and his disappointment really shows. I'm going to take it back to the hobby shop I bought it from and see if they can help. I might need to get the flywheel changed, because it looks terrible. Knowing my luck, they will say the engine is stuffed and not covered under warranty!
I assume you got this worked out. I can assure you, you didn't get a "dud". I am fairly confident you ran the engine too rich for too long and the sleeve is gummed up, and/or not properly seated....causing the piston to keep getting stuck. I base this off the fact I've owned/broken in 40+ engines and have had it happen to me. I've also seen it happen to others quite often. One major misnomer in this hobby is that it's safe to run an engine rich, when in my experience, it's more dangerous than to run it lean. I have conducted a lot of analysis on engines, and I have been unable to damage an engine running it too lean. Normally it cuts out..but never any damage.
Running too rich is a different story, in my experience.
Three tanks of idling is extreme. I'm unsure who instructed you to do that, but you there's your problem. It's not playing it safe, but instead a liability. I had to learn this the hard way. These are facts.
Consider this. You stated three tanks of idling, and 2 tanks of 'easy driving'. So you are five tanks in, correct?
So here, I am on Tank #6:
(scroll to the 2:07 mark)
Years ago I saw someone break in their engine during one of the qualifiers at our track. I couldn't believe it. By the time the mains came around his engine got busy (this guy ended up being a factory drive for Agama, I believe) But this showed me something so I started learning and experiencing. I concluded that you can take and engine and have it broken in and ready for race tuning easily within 5 tanks. I personally go
I'm not saying my way is correct, just that it has worked extremely well for me. The times where I did "take my sweet time" the engine did just what yours did.
All is not lost however, it can be mitigated. It might not run as well as it could have, but in all candor I would just use that engine to learn on and once you cut your teeth to then upgrade as desired. I'll tell you now, this hobby is not for the feint of heart. It will make grown men cry. I see it on the weekly...people who used to run nitro come back and have problems galore. That;s just how nitro is. Stick with it and it will reward you, but if you half-step through it you'll actrually regress (as in I know guys whose vehicles/engines are actually worse than stock). :-)
as far as rich being more damaging than lean, i do have to disagree with you, but it does have to be taken into consideration just how rich/lean and duration of that state of rich/lean. little lean vs. super rich (oil spraying out of exhaust, 4-stroking etc) then yes, the engine will not expand as far as it needs too and the oil wont burn, causing extreme wear in the piston/sleeve walls, and causing too much compression for the engine to sufficiently handle usually damaging the con-rod (if left in this running way too rich state.)
an engine that runs lean will be inherently starved of fuel, which will make it run warm anyways, in the nitros the fuel is in the oil, if there is not enough lubrication the engine will run even hotter still as the materials "rub" against each other. with lack of oil the piston will grind against the sleeve wearing it out extensively.
3 tanks of idling is semi normal in engine manuals, there are many, many different ways to break in an engine. everyone has their own way, but as far as i have seen none has been proven to actually be a better way than the next. imo go off the manual.
going off by what you are saying you most certainly do not have a "DUD", your engine (which hyper engines are known for) has lots and lots of pinch, this is good because it will last a good amount of time.
i believe the issues going on is i dont see where you are pre-heating the engine. use a cheap 13$ heat gun from harbor freight and pre-heat the engine to around 175-200F (do not hold in one spot and leave it, in a swirling motion cover the whole cylinder head and down the glow plug hole and around the block as much as possible.) this will "relax" the piston and sleeve for easier pulls, if this still isnt quite enough back the glow plug up about 1/4 turn until the engine is started then tighten.
