Arrma typhon castle combo issues
I was out bashing around with my typhon yesterday I had a bad landing off a jump buggy had no power. So I got back home put it up on the table and it was giving me a radio glitch code. So I tried to bind it got nothing. I tried a different rx/tx got nothing. Then I realized the esc isn't sending power to my b-link either. So at that point I'd had enough and went in and had dinner and went to bed. Today I look at it again and it's turning on just to a red blinking light no sound or anything just a red blinking light. Any help will be much appreciated. Thank you
Check all wiring connections. Make sure there is no damaged wire/connection.
Make sure your battery is charged and has enough power.
RE-bind Tx/Rx successfully.
Reset/Re-calibrate ESC.
The red blinking light should be gone and everything should be back to normal.
