mugen mbx4xr big bore shocks
NY
how do you tell the difference between these and what the car come with?
OR does a mbx4xr works come with big bore shocks?
also is there a difference between MBX4XR and MBX4XR Works?
CA
RE: mugen mbx4xr big bore shocks
XR and XR Works I believe are the same thing, just some people tend to leave the "Works" part out by accedent. I believe that the XR Works comes with Big-Bore shocks coupled with 3.5mm shock shafts. If hey arent 3.5mm though and they're just 3mm then just dich em and get the 3.5 mm shafts because the 3mm WILL break easily during a race or heavy bash session.
The only way that I can tell the difference between the regular bore and the big-bore shocks is to simply compare them side-by-side. Otherwise you'll have to bust out the ruler or measuring calipers and go in he hard way!
