RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
supercharger kit??does it work??
Old 04-29-2006 | 08:23 AM
  #51
Default RE: supercharger kit??does it work??
well said...it doese4nt work at all actually ....the guys who shelled out 200 bucks for it just dont want to admit it
Old 04-29-2006 | 07:04 PM
  #52
net experts...
take it from someone who has an engineering degree and who has studied engines, forced induction, turbines, and all other power plants, that the benefits of supercharging on these engines are negligible because of the inherent design problems. if u dont want to take it from me, there was an article on this very subject with a dyno chart of the power output. this same subject has been discussed in the monster truck forum, and can be found on the first page. the power output numbers are posted. and there is a link to the issue. the additional HP from the supercharger was less than a 1/10 of a horsepower....
ill be happy to discuss with u why forced induction will not work on these motors.
no flaming, just discussion
Old 05-05-2006 | 07:02 PM
  #53
how about this my friend
i used to have a yamaha motorbike (2 stroke) now the major power came from the "powerband" where the exhaust couldnt let out all the fumes at high revs some of it got pushed back to the engine and depending how big your port hole was you got unbelivable tourue but the problem was you either went crazy fast or silly slow no mid so the clever japs invented a powervalve so at low revs the valve made the port hole small and as the revs built up it opened up creating smooth power all round
so my clever friend would this work on a nitro engine and would it benifit
************************************************** ************************************************** ***********: D
what this space supercharge nonbelivers as soon as my mate back from holiday i will video a race between a siro 27 (2.9hp) and my k4.6 (2.9hp)supercharge both with the same spur/clutchbell gearing so i can show you the real matrix
Old 05-05-2006 | 09:53 PM
  #54
the powervalve might work but it would prob be a engineering nightmare for a rc engine.......heres another idea how about liquid cooling ...that in its self has pontential to be more consistent as far as engine temp....but again prob not worth the agrivation
Old 05-06-2006 | 01:36 PM
  #55
kx250ryder's Avatar
ORIGINAL: motopro
It may be worth it after all. You wouldn't need that giant heatsink, or any of the cooling fins on the engine block. That weight savings alone could equal the weight of a tiny radiator, and a small electric motor to spin the water pump. Food for thought Mr. Rossi.
Old 05-06-2006 | 01:45 PM
  #56
Lets real in the dreaming a little bit here guys. There is no way you are going to implement watercooling AND save weight. The negligable ammount of weight you'd reduce by eliminating cooling fins would be replaced by the weight of the waterjacket and fittings easily. Then the weight of coolant lines, coolant, a pump, and a radiator is all going to be extra weight. In the end you may get more stable temperatures, but it is unlikely you'd get better overall performance since the weight increase would more than offset any power increases...
Old 05-06-2006 | 02:11 PM
  #57
kx250ryder's Avatar
ORIGINAL: dfn_doe
Even if it weighs more, the goal of water cooling is increased compresssion and lower temperatures (less power loss due to heat inefficiency). If you can generate more power, with not much more weight (definitely 1/2 pound or less) its a possibility.
The problem in my mind, wouldn't be weight, it would be manufacturing costs, as well as durability of the engine case at the water jackets, as well as the connecting rod from the increased compression.
Old 05-06-2006 | 02:29 PM
  #58
Jackjet's Avatar
ORIGINAL: pho8nix
Yes Yes Yes i hav seen these superchargers along time ago and was considering to buy one for my inferno. But like one of the guys said above one roll and there goes 130 bucks that could hav gone into a better engine. But i just think that the design isent good enough you see i am an apprentace, a son of a mechanic ( my Dad) and i hav learnt all of this stuff and how a turbos and superchargers work.
But you see the design is only thrusting down air via a fan and it has to make its way through the carbe and get to the engine. I dont think the design is perfected as it should be, it might work and there is only one way to find out. Oh and it will keep up with the engines revs you see they sell different ratios of the pullys and a supercharger runs wright of the crankshaft so every spin of the piston means every spin of the supercharger. That is why a supercharger has basically no lag or better know as Turbo lag.
The best possible way to maximize the performace is to have a computer controlled engine ( fuel injection) Which is probeberly impossible to have because you will need Air, fuel, crankshaft and more sensors hooked up just to get that and look at the size of the engine and car there is no way to get that stuff on the cars engine and chassie.
Blah, blah, blah lets just get a helecopter motor .96 or something and bolt that to your car problem solved lol.[>:][>:]
It CAN be done - 20 years ago I was told "you can't build a gas turbine in model size" - .Yeah. Right. You can do ANYTHING - all it takes is DESIRE and some money.
Jackjet
