needle settings help .....
hi, there is not any proper settings for any nitro engine but if you look in your manual it should tell you the factory settings and work from there
I just got the wasp 26 for my MGT and the manual says 3 1/2 on the hsn, and 10.5 to 11.5 on the lsn. But, when you turn the lsn out that many turns it is nearly all the way out, if you cut it in half, the needle will be flush with the slide which is where it probally should be. If you can find a phone no. for team orion let me know, cause I have not found it yet.
