Inferno Sports rtr stalls at low speeds
MB, SPAIN
Hi! I got a Kyosho Inferno Sports and it runs fine at high speeds but it stalls at low speeds or in idle...even when I take a corner at low speeds it normaly stalls...I can never run a full tank without it stalling.
I have the idle a bit high to try to stop this... and he car runs away if you dont aply brakes
Any Ideas?
thanks
Any Ideas?
thanks
RE: Inferno Sports rtr stalls at low speeds
First, put the idle set screw back, tuning the LSN with that out of place will mess you up.
I tune my LSN by letting it idle for only 20 seconds before it dies. If it idles any more richen the needle (counter clockwise). If it idles and less, lean it (clockwise). I also run 20%. 30% has enough kick that it won't die so my method doesn't help you there.
MB, SPAIN
richen means more fuel in no?
lean means less fuel ni no?
I thought richen whas clockwise and lean anti clockwise
at least clockwise with idle screw makes rpms go up
and anti clockwise makes rpms go down
ORIGINAL: splash1
ORIGINAL: splash1
ORIGINAL: splash1
Anyway, clockwise is lean (more performance) and counter clockwise is rich (less performance). It's a weird concept that you'll get used to.
-RobH
MB, SPAIN
thanks for you help robh
is there any way to chat in a chat room or messenger? to talk a bit faster?
[email protected] is my messenger if you can
I've never sign up for MSN messager. I have Yahoo Messanger ( roberthamilton77 ). I could hop on IRC if you know what that is -- if not don't worry about it.
