RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Diff ?
Old 02-29-2004 | 09:31 PM
Default Diff ?
I recently became the proud owner of the Limited Edition GS Storm Unlimited Truck with the .25 engine. I noticed on the diff cases there is 1 small set screw on each of the 3 diffs. When I tighten then down it locks the diff. If this what these set screws are meant for? If not what are they for? And would it do any damage if I did use them to lock the diffs? Thanks a million
Jay
BTW if you're wondering why I put this is in here...The GS Storm SUT is a converted buggy.
Old 02-29-2004 | 10:19 PM
BOOCAKE4U's Avatar
Default RE: Diff ?
not 100% sure on the GS as i don't have one, but on most designs there is a hole (and set screw) on the side of the diff case at the closed end (the end without a gear screwed to it) to allow you to slide in the little pin that holds the larger internal diff gear to the drive cup which exits that end of the diff...hope that made sense...if you have the manual or an exploded view of the diff it should be clear what i mean...
Old 02-29-2004 | 11:45 PM
scale only 4 me's Avatar
My Feedback: (158)
Default RE: Diff ?
that's what I was thinking too Boo,
I wouldn't run it that way, you are pinching that set screw against one of the diff ring gears.
nothing good could come from this.
Old 02-29-2004 | 11:56 PM
Default RE: Diff ?
sorry for crappy pic, i dont have a macro lens. the screw right in the middle on the side of the diff case is the on i think he speaks of.
Old 03-01-2004 | 12:52 AM
Default RE: Diff ?
ok cool. Thanks for the info. Another question...How would I go about making that center diff a lot harder to turn? I mean when I accelerate from a dead stop hard, the front end comes up slightly and then all my torque runs to the front. Maybe not totally locked but pretty tough for it to spin. Any suggetions?
Old 03-01-2004 | 12:57 AM
Default RE: Diff ?
stick 30k wieght silicone in the center diff. very thick. stick 10k in the from and 5k in the rear. 10/30/5
i have a storm and thats what i use. helps keep the center in order and the front from unloading during turns and loss of traction.
